Ed Dumas
Member
I just discovered that an amp I gave to my daughter a few years back is actually quite a gem. It is an Optonica SM4646. Optonica was high end to Sharp like Technics was high end to Panasonic. The SM4646, it turns out, was Optonica's top of the line amp for about 1976/77. Optonica brand did not do so well because Sharp entered the high-end market late, and not enough people knew the name for them to grab enough share of the market to keep the line going. To give you an idea of the build quality, Optonica committed to putting three transformers into this gem, one for each side of the power amp, plus one for the pre-amp portion.
So, I have offered to my daughter to do a re-build on her amp for free to return it back to factory specs. I will put new electrolytic caps, put in a new relay switch, clean all the switches and control pots, replace any bad trim-pots inside, replace the double transistors which tend to go, and adjust back to factory specs. I have a service manual already for it.
Does anyone out there have any experience with Optonica? Are there any perils in this amp that I should watch out for?
