Koloderko
Good point about the cardboard ring. Thanks! I'm looking at some speakers now that, if I get them, could use a refoam and I'll keep that in mind. Is replacing butyl surrounds also called "refoaming"?If someone put foam surrounds on the speakers in the OP, without removing the cardboard gasket ring behind the surrounds- then they did it wrong
The replacement foam surrounds available, all will only line up properly (as in not be trying to pull the cone forward, at rest), if the surrounds are flat on the metal basket. I've had to rework a number of those, that people mistakenly didn't remove the cardboard ring before refoaming...
Regards,
Gordon.
