Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Those risers were available seperately for the later Version 1; I believe they were standard on the Heresy II. See if you can get dimensions for them and make your own - that is what I did for my COrnwalls I's, to turn them into 1/2s heh.
My Heresy I's came with risers. Very simple. They are 12 1/4 x 13 7/8 inches square. The material (looks like birch plywood covered with walnut veneer to match the speakers) is 3/4 inch thick. The height is 1 inch with no tilt or slope to them. They have 4 holes drilled in each one if you want to screw them to the speaker. On the bottom corners are silver legs that look like oversized thumbtacks. I can add photos if anyone wants them. I have mine on stands which sounded better than the risers to me.
My HII's did not have them so I made mine using 3/4in Pine and tapered them from 2in in front to about 1/2in at reare then glued them to the bottom with my wife;s Hotmelt glue gun. They are firmly attached but can be removed if necessary without damaging the speaker box. Works fine took about 5 minutes. Since I refinished my HII's in Piano Gloss Black I sprayed the risers with Krylon Satin Black. The look and work great. . .
Blue Tac would work as well. . .
I actually prefer them sitting on the floor since it warms them up a bit. Originally mine came with stands that I still have but do not use. . . I was told they were original that I doubt but he could have purchased the stands at the same time thinking they were OEM. . .
nope, those are too small. i have those risers on my kg4's, and they sound great with them. i might just have to build some. i do want the sloped risers though.
damn, those are exactly what i want...same color and all! ill have to get my friend over here who has an account, to contact the seller and see if they are still available. thanks!
