Ortofon Blue MC Q10 Cartridge, MC or MM ?
liemjerry
Well-Known Member
Dear Friends
Please help identify this cartridge :
Ortofon MC Q10 blue
Is this cartridge MC or MM ?
Anyone use that cartridge? how about the quality?
Thanks
That's a Quintet Blue, moving coil with an elliptical stylus. The MC printed on the case is a good clue that it's moving coil.
I have used it's upmarket sibling (Quintet Bronze) and it is very high quality.
Edit/Add - good to have VTA adjustment with that cartridge, my Bronze is about 2mm higher than my Audio-Technica cartridge is...
Thank you for information because before I ask I rather confused for this cartridge : MM or MC..
what's the difference with this one :
https://www.ortofon.com/mc-quintet-blue-p-547
Its a true MC with only . 5 mv output so you will need a step up transformer to drive a MM input or a Phono pre-amp designed for MC cartridges to drive a line input preferably. A good pre-amp cost a lot more than the cartridge.. I prefer a pre-amp so you can match the preferred impedance and gain for the specific MC cartridge you choose. That said I am using a HO Dynavector right now, but do have the Phono pre-amp for when I am ready to move up to a XX-2 model from my 20 X 2 and 10X 5.
so I can't connect this cartridge to a common pre-amp that support MM, do I ?
and I must use phono stage? or pre-amp that support MC ?
Right. It’s a MC cartridge.
Some MC cartridges are high output, and work fine with a MM phono amp. The fact that it is a MC design does NOT necessarily mean that it requires a specialized phono amp. This requirement is a function of its low output level...not its construction.
Yes, at 0.5mV it is considered a low-output MC that will not work well connected to a MM phono stage. And to clarify, any MM or MC cartridge requires a phono stage to add RIAA equalization and gain, and this can take several forms for that cartridge:
MC phono stage built into a preamp
MM phono stage built into a preamp, fed by an intermediate gain device (step-up phono transformer or phono head amp, that will add 20db or more of gain)
You also can get external phono stages, these will plug into a non-phono input on your preamp. Functionally they are very similar to what is inside of a preamp's phono stage.
Good luck, it does not sound like you currently have what you need to effectively use that cartridge.
note - edited for spelling
@spark1 - right but the output was previously stated.
In response to the OPs request for clarification, you basically said that he needs a higher gain phono stage because it's a MC cartridge. This is not correct. It needs a high gain preamp because it has very low output. This is not the case for all MC cartridges.
Ok, but I already know that and the output was previously posted so a SUT is required or a preamp section accommodating LO MCs will be needed. Nothing incorrect with that.
Hey guys let's just use the proper terms when calling out a cartridge as moving coil.
HOMC, high output moving coil suitable for connecting to an MM input, but may require more volume control to get full output since these are usually in the 1.8-2-8mV output level
LOMC, low output moving coil with an output level of more than 0.1mV to about 1.0mV requiring a typical moving coil Phono Input, SUT or phono preamp that will handle a LOMC
VLOMC, a very low output moving coil cartridge such as the Ortofon MC-20 with a 0.07mV output. This one requires an additional 10dB of gain to be similar to the others. The phono pre for this cartridge has 34.5dB of gain to an MM Phono input.
Can we just add a few letters to the front of the MC to clarify this instead of arguing about it?
No arguments here. ;) I suppose you could do the same with MM and MI as well as some of the VR cartridges. Some with very low and other high output.
So we agree that moving coil designs do not necessarily imply the need for a step-up or high gain phono amp.
"Right. It’s a MC cartridge".
Right. It's a low output cartridge, as are most, but not all, moving coil designs.
Helpful if you provided a price range but I can highly recommend the Emotiva XPS-1. Very flexible for a solid price point and first foray into phono pre's.
