ortofon cadenza blue vs audiotechnica
Hi, Have you tried swapping your Head-shell leads around. And if so did the mismatch in noise/vol travel with it to the opposite speaker?
Cheers
Cheers
This is valid, if you have pos and neg correct on one side and wrong on the other the reverse phase cancels some music that is in both channels and one channel will be lower volume.
Chris
I have swapped the leads from the player to my phono amp and the problem also swapped sides.
Like I wrote in post #7 I expected that the cable had to be fixed or replaced. The repair company did what you proposed (by my request) to prove that the problem is indeed in the cartridge
Hi, That's not what Chris & I asked. Swap the head-shell leads from the cart & make sure the polarity is correct.
Cheers
