Ortofon cartridge identification help please
No Money
Hi, I have what I believe is an Oftofon FF cartridge body here, but I have also been told it might be a VMS ... Colour me confused. I always thought the VMS ones had a "key" at the bottom.
Can anyone clarify for me. After a few internet searches I am even more confused.
Thanking all in advance.
I have 2 similar Ortofons here. The bodies look the same as yours except the opening does not have the hourglass shape with the narrow waist; it's just a rectangle. One of them has a VMS stylus in it and the other an FF and they both have the hourglass shape insert.
I don't know if that helps or adds to the confusion. I think (but can't be sure) I bought at least one of the styli from VOM. I do know the hourglass shape on the stylus will fit the rectangle in the body but the reverse will not work.
OK, thanks Stanton, that helps a bit, will look closer at the cartridge later.
Would be a lot easier if I still had the stylus ............................
FL is hour glass mkii, and vms is x shape mkii. I have the vms 20e mkii, and had an ff15e. They are not interchangeable though. Yours should be the first version. You can use other ff stylus.
