Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Hi ! I restored an Ortofon RMG212 and installed as per Ortofon specifications a 32g headshell. With the counterweight set to 0, my initial mass is already about 8g (it should be 0g), so I can't apply a 4g on the cartridge. Any recommendations?
check if there is a hole in the side of the counterweight ,if so ,loosen the grubscrew inside .
This should enable you to move the counterweight .getting the arm/ headshell /cartridge combi. in neutral (0gr. downforce ) set at 0 on the weight.
See :https://cdn.shopify.com/s/files/1/0756/9247/4651/files/ortofon_tonearm_rmg_309.jpg?v=1704356923
Top right pic. : Blocking screw .
Hope this helps ,regards F.
