Update #3Did you ever check those capacitors? Play a square wave into a dummy load with 100 W DBT just to be safe and tap away while observing your scope.
Well, I took all suggestions to heart and did the following in order: changed out the 10pf cap and made it 20 on c363. Checked all other miller caps and added 10pf. Could not reproduce oscillation. But when I started tapping, I got no change in the scope tapping anywhere in the amplifier section. But I got some jittering in the scope when I tapped in the other side of the board. I looked very carefully and found some suspect solder joints in the areas of the inputs and speaker terminals. Reflowed all those joints and tested. This time got just a tad when I tapped in a very specific area. Reflowed all joints there and went back and very carefully examined the board for cracks etc. I had previously found and repaired a burnt trace when the left channel failed before I undertook an attempt to fix this sucker (and it has been a time sucker for sure). I think I finally got it. Not seeing any signs of jitter or oscillation in testing and square waves look normal. Will just have to let it cook now for several hours as a final test. Thank you to all who chimed in. This is why I hang out here and how I learn. Even an old dog can pick up a few new tricks!
