mschmitzusa
I have read a lot about output transformers lately and learned a lot. However there are a few things I have difficulties with. Here are some questions coming up. I have read a lot about paralleling output transformers to get more power and also the ability to get odd impedances etc. Here is my story: I am in the process of building some sweep tube amp and thought of like a Bogen DB130 clone and maybe even double up on output tubes for more Watts. The problem is that universal outputs available are made either for table radios or guitar amplifiers. I want Hifi, but the regular production output transformers are made for the commonly used output tubes only and do not have the impedances I need. A custom winding job I can't afford, just like I can't afford to pay hundreds of dollars for a quad of EL34 or KT77 or KT88 tubes after the sanctions on Russia and the resulting quadrupling of output tube prices, where as sweep tubes cost 3 to 5USD NOS a piece. I heard of people paralleling lower grade (guitar or console) output transformers for example and only loading them to about 50% of the transformer VA rating and claiming to improve frequency response due to increased iron and copper without changing in and output impedance. I spoke to Edcor and Hammond, but since they are in the selling transformer business, they were not very helpful and tried to push me into the very expensive custom winding job realm. I found an Edcor XPP15-7.6K with 6Ohm output and 70Hz to 18kHz at 1dB output, which has a 6Ohm output that I could load with 8Ohm instead to get my desired primary impedance of 11400kOhm. Unfortunately, that transformer is only 15Watt and I need very close to 40Watt. I asked Edcor and did not get straight or enlightening out of the box answers. Now I am asking the Audiokarma community, if I parallel three of them to get 45Watts output, will the increased iron core made up of 3 cores increase my low and high frequency into the 20 to 20kHz at 1dB or close by area? Six of those transformers can buy for what Edcor charges as setup fee alone to make a custom winding job, you still have to pay on top for. Kindly advise and give me a good lesson on that subject. Thanks!
