Shadowdog
This isn't 10K primary like the originals , but has a 6.6K which is used in fixed bias for the 6L6/KT-66.
It should have more interleaving (likely similar to Dynaco) than Edcors so should be a better buy. You can also buy them from the manufacturer.
http://www.triodeelectronics.com/40-18080.html
On the other end of the scale Hashimoto has a 10K 40W one @ about $360 ea. Not sure on UL tap specs , but I think they will maybe build to order that way. If you want original sonics and used are too pricey they may be the way to go. Likely last with no worries about used dying !
