FlaCharlie
So I'm thinking about trying either some Russian 4P1L (a directly heated pentode) or its cousin the 12P17L (an indirectly heated pentode) in PP and I'm trying to get an idea of what OT primary value would be most suitable.
I know tubes are fairly forgiving when it comes to differences in load but I'd like to see if I have anything in my junkbox that's in the ballpark.
The 4P1L is quite popular wired as a triode and is typically used in PSE (parallel single-ended) configurations using OTs with ~3k primaries.
So, two questions:
What primary would be suitable for PP with tubes wired as pentodes?
What primary would be suitable for PP with tubes wired as triodes?
Here's the data sheet for the 4P1L, which is the third tube listed. It seems that footnotes 1, 2 and 3 apply and that in Class A1 (a single tube in, I assume, pentode) the tube produces 1.5w with a 6k load and 2.6w with a 7k load. But there's no info on PP operation.
The data sheet for the 12P17L doesn't seem to list any info regarding proper loads or power output.
I know that the load in PSE should be half of the SE load. I assume that PP load will be higher than SE but how much higher? Double?
So, two questions:
