pskaudio
No user serviceable parts inside me...
What do you mean?
In speaker design, The distance between the drivers and what frequency range they cover go hand in hand. There is a certain amount of overlap between the woofers and mids, mids and tweets. This is a function of any crossover and the overlap is dependent on the slope (6dB per octave, 12dB, 18dB, etc...). The combined output from the drivers causes interference patterns. The further they are apart the worse the effects of these patterns. This would be in a single enclosure, with just one driver handling a part of the frequency spectrum. Since you have two enclosures per side with both mids and tweets producing the same frequencies and very far apart, there are all sorts of reinforcements and cancellations occurring due to interference patterns.
If you really want to stack them, try turning the top speaker upside down. This will bring the higher frequency drivers closer and the above problems are most pronounced in that range. It's not the ideal situation, but I bet you'll notice an improvement in your system's sound.
