raindance
Member
Guys, there is NO WAY a volume pot will cause distortion. The key is two things: 1. Is the ALPS an audio taper (log)?
2. You disconnected circuitry for the loudness circuit that is not meant to be left open circuit.
The ALPS pots (I use the blue a lot) are excellent and track well. They are also tough and can handle a hacksaw on the shaft so long as you clamp it to prevent rotation. As for cutting off the locating pin you can break it off with pliers or cut it but you must cover the openings with painter's tape to prevent crap getting in.
Lastly the ALPS blue sometimes needs the metal body earthed to a signal ground at the input stage if the chassis is floating. This affects only hum and not sound quality.
