Pass 40/40 Coherent Reference Amplifiers
Interestingly marked as Pass 40. It uses MPSA42, MPS6571, MPSA92. Drivers are MJE172 and MJE182.
All are still made except MPS6571, but I should be able to find a sub.
The original A40 used MPSL01 and MPSL51. Did you look/find the original A40 schematic? You can download the whole article from PASS Diy.
Taking much longer than I thought to make the schematic.
I found this thread by Nelson Pass, and I'm wondering if it would work for what I have?
I think I need to make sure the outputs are hooked up as the Threshold unit was, but otherwise everything looks good.
For my single user application, I want to figure out how to omit the thermostat (T switch) and the 2k thermistor.
I also have no idea what the R25-28 and C7-8 situation is going on.
Jumpering out T should be easy enough but I don't have a suggestion for TH1.
The first thing I thought of with the R25-28, C7-8 section is a zobel.
Thanks!
I looked at my boards again and I do in fact have a thermistor so I’ll leave it.
Apparently those parts are for some Threshold models that have cascade outputs. The thread on DIYAudio is so long it gets confusing.
I finally realized I just need to keep the board as identical as possible down to the traces, then it's easy to see if it's correct or not. Ordered boards today and I'm excited, mainly because the working unit sounds so dang good!
Using 2N5089 or MPSA18 for the MPS6571.
I would have liked to incorporate Nelson's new design with the FET input, but my skills are too limited.
