Oh cool what’s a chip amp ??Personally, I prefer a cheapie chip amp with a real pair of bookshelf speakers. Huge SQ upgrade from those PC speakers, imo. Consider it, watch for a deal.
Whenever you see a word or phrase you don't know, try googling it.Oh cool what’s a chip amp ??
I don’t have the money for an amplifier right now , any way to use both speakers ? Or do you need a audio splitter cable ?Whenever you see a word or phrase you don't know, try googling it.
If googling doesn't give you the complete answer you're looking for, then ask questions.
Without an amplifier, speakers on their own are useless except as ornaments.I don’t have the money for an amplifier right now , any way to use both speakers ? Or do you need a audio splitter cable ?
They are powered pc speakers , I want them to get the signal ,along with the other pc sub.Without an amplifier, speakers on their own are useless except as ornaments.
I'm not clear how you intend to use an audio splitter cable. Could you explain?
You mean you've got a set of working PC speakers without a subwoofer?They are powered pc speakers , I want them to get the signal ,along with the other pc sub.
The speakers work they just are dreadful and the sub is decent, better then the pioneer speakers .You mean you've got a set of working PC speakers without a subwoofer?
And you've got a subwoofer without working speakers?
And you want to combine the (hopefully working) subwoofer with the working PC speakers?
Sorry, but not likely. PC speakers are typically constructed as an integrated set. PC speakers that didn't originally come with a subwoofer will not easily accommodate a subwoofer from a different manufacturer. That would require considerable customisation only to wind up with a poor-sounding result.
Yes correct we have winner .seems like he has an input to his sub from the picture and I think he wants to know how he can drive his other two speakers from the same source but only has one cable going to sub from a computer or something.
Really?Yes correct we have winner .
I have better pc speakers it’s a temporary fix til I get a soldiering thing . ‘What’s a splitter cost ? Probably same as soldier hahaReally?
I'm afraid I don't understand either of you or the pictures, and I'm not clear what is being attempted here, though if it involves attaching a standard subwoofer in parallel with PC speakers (does it?), a typical audio splitter cable will work as long as the subwoofer has a line-level input.
Though note that the PC speakers on this page are going to sound awful. Almost any bookshelf speakers will sound waaaay better than cheap PC speakers (which often sport drivers that would be inadequate in a transistor radio), and any stereo amplifier -- vintage or new -- will provide vastly superior results to the crude high-distortion, low power amplification provided in typical low-end PC speakers.
Yes, those appear to be line level outputs with no volume control so if the other PC speakers can get input and have a volume control on them then that could work. The question then is do the speakers have a volume control and what cable is needed to do the connection. It will be an adapter cable for sure.If your little speakers are powered (plugged into the wall with a built in amp) I imagine you can use the line level outputs on the back of the sub
