Coming into the 5000A has, of course, led to my discovery/awareness of the single digits as well and my eyes are wide open.I had both the 800 and a 5000X. Both sounded great. Agree the 800 has a sound well beyond what you'd expect. The reason I sold that one, it could not really be played at low volume. The volume pot on many of these does not go to "zero sound" at the bottom setting. Don't know if they came from the factory that way, or if the pots were prone to deterioration over time, but the one I had did not completely cut the volume. (Some have reported the same issue with AU-777 volume pots, though mine does not have this issue.) Also, the 800 gets loud fast (no muting switch to help attenuate), and I generally don't play music in spaces were LOUD works. So, I moved that one along after using it in the garage for a while.
The 5000X I had no complaints about. Great, full sound, good tuner, etc., though definitely "warmer" than all my other Sansui gear. I had kind of "maxed out" my space for collecting amps/receivers, so something had to go when a new one came in. In the end I favored the "single digit" receivers I have over the 5000X.
Okay, understood. Thank you, @LBPete. I've since gathered a variety of lower wattage incandescent bulbs including 25w, 40w, and 60w. I was under the impression that the wattage of the bulb was supposed to approximate to the wattage of the amp being tested. Is that wrong, misguided? I feel like I picked that up around here or on YouTube. If the 800 I want to power up for the first time later is ~22w, should I use the 25w bulb, or one of the others?A 200w bulb in a DBT does not limit current enough. With incandescent bulbs, the higher the wattage the lower the resistance. 100w is minimal for general protection but use 60w for a unit with no history.
- Pete
Okay, yes. There is a bulb in that location under a shroud that I didn't mess with. I also see the red stereo light in pictures on the web. I missed that. I'll revisit. I changed the four bulbs behind the dial. The tuning meter bulb is still original and working. I didn't change that one because it's hard to get to from the top side. I think the faceplate probably has to come off. Thanks.FYI, there is also a (green) light above the tuning meter that indicates when power is on. Looks like yours is out.
Is the red stereo light out also?
There is no connection between the wattage of the unit and the wattage of the bulb. A 100w and a 60w bulb will handle almost any situation. If you go lower than 60w it may drop the voltage to the point that the protection circuit will stay engaged and not turn on the speaker relay. Use a 60w bulb if you are powering up something for the first time. Use the 100w bulb to give a level of protection while working on a unit.Okay, understood. Thank you, @LBPete. I've since gathered a variety of lower wattage incandescent bulbs including 25w, 40w, and 60w. I was under the impression that the wattage of the bulb was supposed to approximate to the wattage of the amp being tested. Is that wrong, misguided? I feel like I picked that up around here or on YouTube. If the 800 I want to power up for the first time later is ~22w, should I use the 25w bulb, or one of the others?
I'm handy enough with tools, mechanical assembly, tinker toys, and cleaning, but I really don't understand electricity and all the values and measurements. I'm going to need a course in using my multimeter - that thing may as well be a baked potato for all I know what to do with it.
Okay, got it. Thanks!There is no connection between the wattage of the unit and the wattage of the bulb. A 100w and a 60w bulb will handle almost any situation. If you go lower than 60w it may drop the voltage to the point that the protection circuit will stay engaged and not turn on the speaker relay. Use a 60w bulb if you are powering up something for the first time. Use the 100w bulb to give a level of protection while working on a unit.
- Pete
Got the power lamp replaced. The red stereo lamp, however, is sequestered in its own tiny metal box and I can't figure out how to get to it short of a tear down that I don't have in me right now. It also appears that it's a smaller lamp, maybe, given the size of its little metal box? Original meter lamp is still in tact and working too. That one also seems very tricky to get to. Shop Rig 800 is looking good, otherwise!FYI, there is also a (green) light above the tuning meter that indicates when power is on. Looks like yours is out.
Absolutely mint cosmetically, no question.That's a shame. Nice looking unit.
