Hello,
I am in the very early stages of my journey to resto-mod one of two PL-400 Phase Linear amplifiers that I own.
I am going to do everything. FULL WOPL. White Oak Phase Linear in Full Comp Mode.
Backplane boards. Control Board. Light board. Capacitor Kit (ADDED: I went with a different capacitor setup, read about it below), and last but not least the DC Circuit Speaker Protection Kit from another seller.
I already stripped the chassis bare. I rerouted the AC wiring to the top of the chassis. And I built a new bus bar grounding bar that attaches to the capacitors -- with 10-32 threaded holes near the middle of the bar. So, instead of soldering all of the ground wires to it, I'm gonna thread them on using eyelets/bolts.
I have located all of the info to do this job. I've downloaded and read everything about everything. I've watched the YouTube videos. I have MOST not all of the test equipment. When I start I am gonna add pics and start a running discussion. It might take me months to do everything, but as God is my witness, I am gonna do this!!!
So. My first roadblock. My first question that it seems I cannot find an answer to, is this:
There is a diode bridge (S25A20 Bridge Rectifier 25A 200V) that is secured to the top of the transformer. I have seen photos and I have also read about where this thing has been modified. It involves soldering between the four posts four film caps. The size that I found is 0.01uf (103K) 400V standard film capacitors.
I cannot for the life of me find much on this modification or that it is in fact necessary. I was hoping that some of you fine folks here and Audiokarma could shed some light on the matter and if you could give me info on a new bridge rectifier or instruct me on how to modify the original one.
Thank you. And let the fun begin!!!
