Phillips 673 Tuner Amp pairing HELP
Axcel
Accuphase all the way
I just picked up this Phillips tuner and am playing thru my realistic sta 2100. A waste I know being a receiver and all the Phillips is so much better then the very good fm section on the rec'r. Question what amp 100 watt + would you pair with it ? I'd love to find the Phillips amp- pre amp but there scarce . Any suggestions?:music:
I like Luxman. An L-100 would be nice.
Yamaha has the M-80 power amp, I forget what the matching pre is. You can't go wrong with Kenwood's KA integrated series.
The Philips tuner I had was on the "accurate" side compared to Sony, Sanyo, Marantz, and MacIntosh tuners I've owned.
If you want your system to be clinically accurate, then go with a Yamaha. If you want "warmth" then get an amp on the warm side like a Marantz or a McIntosh.
I'd think the best balance might be a Sony integrated like the TA-1120A or TA-F808ES or a TA-2000F/TA-3200 pre/main combo.
Other combinations exist, of course.
hi axcel,
i dont know about you but i like to have matching gear.the phillips amp and preamp definately mate well and sound good with the tuner although they dont get the respect the tuner does.both do show up on ebay although not as frequent as other gear but they do show up .if your patient i'd wait and grab the matching gear but thats just me.
Phillips 673
hi axcel,
Think Iam going to take your advice and wait simply love the tuner and would LOVE to get the matching units:music:
With separates, I am a mix-and-match.
Yamaha are great. What is your budget or what power class are you wanting?
I might just be offloading my Philips High fidelity Laboratories Power Amplifier 3671. It has an output of 200W per channel and will peak at 400W per channel. Really too much juice than I need even though a beautiful performer.
dont you meen the 5781? the only thing ithat comes close to the number you gave is a 3861 or 3881 but those are integrateds and dont even come close to 200w output.the 3861 is good for 60w/ch and the 3881 80watts/ch.fwiw the 3881 was the highest power integrated they put out.
chris
chris
You definitely right the one I have is a 5781 and which as I pointed out is rated at 200W per channel and peaks at 400W per channel. Thanks for pointing that out.
no problem ,its hard sometimes to keep track of all the model numbers of different gear.i had the complete setup along with 2 of the tuners 1 673 and 1 6731 unfortunately eveything is gone except the 2 integrateds and the 185 tuner.:sigh:
What is the difference between the 673 and 6731 tuners ?
one is black the other silver .with all the hi fi lab series of gear the number 1 at the end of the model # designated black.for example the 673 would be silver and the 6731 would be black.hope this helps.it worked the same way with the receivers and integrateds also.
chris
Well, Axcel just picked up my Philips Lab Series separates system, tuner, preamp and amp to give a test drive to see how he likes it. He's running some nice Accuphase. If he likes it we'll cut a deal and if not he'll drop it off and I'll reshelve it.
units
mighty impressed by what I hear so far:music:. Hard to believe these get no respect or following:scratch2:
