I know, I know...another phono / turntable hum troubleshooting post. In this case, however, I am rather certain that my turntable is not the issue. I think it is the Phono "Equalizer" / Stage on my MCS 2250 amp -- which is essentially a Technics SU-Z400 (manual here). This hum only occurs on Phono input, not an Aux or Tuner, etc.
How have I come to this conclusion? Well to begin, the hum is there when I spin a record, of course -- it is faint, but can definitely hear it when volume is high (granted higher than I normally would listen). Next I unplugged everything from the amp except for my speakers. Hum is gone. Then I start to just plug RCA cables into my amp and BOOM there is a loud crashing noise -- on both the right and left speakers. When I finally plug all the way in, the hum is back. There is nothing on the other side of these RCA cables, I have not even plugged the turntable in yet.
As an aside, I took some of the cabinet off to have a look and see if there was anything obvious wrong. I turned the amp on while the cabinet was off, and the hum was there with nothing plugged in. Does the cabinet somehow function as ground? Again when the cabinet is on, and nothing is plugged in, there is no hum. Then reintroduce a cable (with nothing on the other end), hum is back.
Am I diagnosing this correctly that the amp is the issue? I have tested different cables. Is there any recourse here with my amp? Is it the phono stage itself, or maybe just the RCA connections? I am only a beginner here, I am good with a soldering iron but don't have a multimeter. But maybe now is the time.
Thanks in advance.
Thanks in advance.
