G'day all, I was just thinking about input capacitance and loading, and I realised that a lot of commercially made phono stages either do not publish input capacitance figures and/or are quite high, making them unsuitable for some otherwise very good MM phono cartridges (like the Shure M97xE). 220 picofarads seems to be a popular value, although too high for the M97xE when tonearm wiring and interconnect cable capacitance are added into the equation.
My ANT Kora's input capacitance is 100 picofarads, a pretty well ideal value, and my TCC TC-750 is 220 picofarads (factory default value), which I have changed to 100 picofarads.
If the input capacitance is low, one can always add capacitors, but generally it is not easy to change, if the input capacitance is already too high without 'surgery', although using shorter interconnects might be an option.
Anyway I was thinking we might compile a list of various phono stages input capacitance (if available), as this will definitely help with optimal cartridge capacitance loading. The value might be gleaned from a circuit diagram. Regards, Felix aka catman.
