Question about capacitance and selecting an appropriate cartridge. I just purchased a Dual 1229Q and looking at replacing the cartridge that came with it. I was looking at the M91ED, V15 type III or the M97xE and of course I will be changing out the stylus for either an LPGear VL or a Jico HE or SAS. I have a Sansui G5700 Receiver but not sure after having read some of Catman's other posts if my system will perform well with those cartridges due to the pF. I have attached the schematics if anyone can help me decipher it.
Here are the Schematics for the Sansui G5700.
View attachment 1919568View attachment 1919569
Good news - the Sansui has an input capacitance (Left = C05 and Right = C06) for each channel of 100pF.
So it should match virtually any cartridge, assuming the output leads of your 1229Q are low capacitance. I seem to remember that the 1229Q was the quadraphonic model, which would require output lead capacitance of 100pF or less (for CD-4 quad cartridges), so if it has those leads, you'll need to add some extra capacitance to the inputs of the amp (easily done). The capacitance required for the cartridges you mentioned are
Shure M91ED (originally paired with the stereo 1229) and V15 Type III: 400-500pF needed - subtract 100pF for the amp, then subtract the measured capacitance of your turntable output leads, to find out how much extra you'll need to add, to get a flat response from those two cartridges.
Shure M97xE (and all other Shure cartridges released after 1978, including the V15 Type IV): 200-300pF required. So you'll need to add less extra capacitance (possibly none) to the turntable leads and receiver input to get the flattest response from an M97XE or other post-78 Shure (or any Stanton).
If you do have the very low capacitance leads (less than 100pF) that quad turntables typically had, you'll (probably) also be able to choose any Goldring or Audio-Technica MM cartridge , or any Nagaoka MI, as they require 100-200pF.
Note that you do need to measure the capacitance of the turntable leads (without a cartridge connected) to be sure what you need. Many modern digital multimeters (but not the cheapest) often have a very accurate (typically better than 5% accuracy) capacitance range, so if you need to buy one, check that it does have a capacitance range that is good for pF (say up to a maximum of 2nF or 2000pF).
