Pictures of Japanese NEC 12AD7 Tubes
kcline
Tube Audio Collector
These came out of a early Sony R to R. Hard to find, as a retired tube dealer I have never seen more then a handful of these.DSCN0844.JPG DSCN0847.JPG DSCN0845.JPG DSCN0846.JPG Sockets in the r to r were marked 12AD7/ 12AX7
The only thing I see different in the spec's is the interelectrode capacitances which are very slightly higher in the 12ax7, and the heaters in the 12ad7 are higher amperage. Otherwise they are pretty much identical. You could sub a 12ax7 for the 12ad7, but beware of 12ad7 for a 12ax7 due to increased load from the heaters, especially if your heater circuit is close to maxxed out.
12ad7
Substitute Data
Preferred Substitutes ......................... 12AX7 12DF7
Substitutes ................................... 12BZ7
10782
Mechanical Data
EIA Outline ................................... 6-2
EIA Base ...................................... 9A
Electrical Data
Heater Voltage ................................ 6.3/12.6 V
Heater Current ................................ 0.45/0.225 A
Direct Interelectrode Capacitances (approx)
Triode
Input ......................................... 1.6 pf
Output ........................................ 0.5 pf
Grid to Plate ................................. 1.8 pf
Characteristics and Typical Operation
Class A Amplifier
Plate Voltage ................................. 250 V
Grid No. 1 Voltage ............................ -2 V
Amplification Factor .......................... 100
Plate Resistance (approx) ..................... 62.5K Ω
Transconductance .............................. 1600 µMho
Plate Current ................................. 1.25 mA
12ax7
Substitute Data
Preferred Substitutes ......................... 12DF7 12DM7
Substitutes ................................... 12AD7
Source ........................................ GE - 1973
10982
Application
Miniature type used as phase inverter or amplifier in ac/dc radio equipment and in many diversified applications such a multivibrators or oscillators in industrial control devices. Requires noval 9-contact socket.
Mechanical Data
Bulb .......................................... T-6 1/2
Base Type ..................................... Small Button 9-Pin
Mounting Position ............................. Any
Electrical Data
Heater Current ................................ 0.3/0.15 A
Each Triode
Input ......................................... 1.8 pf
Output ........................................ 1.9 pf
Grid to Plate ................................. 1.7 pf
Maximum Ratings (Design Center Values)
Each Triode
Plate Voltage ................................. 330 V
Plate Dissipation ............................. 1.2 W
Class A Amplifier
Plate Current ................................. 1.2 mA
For other characteristics and typical operation, see 12AX7A
