Thanks for the update. Could you fill us in a little more? What stylus did you get?
There are three aftermarket styli floating around that I'm aware of. There's the yellow Pfanstiehl 707-DE and the black EVG PM2891DE. Both of these have a "STEREO" sticker where the "SC-100" sticker on the original was. These both are true induced magnet cartridges and designed to be used with the tri-pole body. They appear to be JICOs.
The third one is the Pfanstiehl 4707-DE. These are black, have no sticker on them, are probably Swiss and are neither induced magnet nor designed for a tri-pole cartridge. Instead, they're moving magnet styli of a V-magnet design like Audo-Technicas. They work but they're not right.
The two JICOs are pretty nice. I've not heard the 4707-DE but I wouldn't expect much from it.
Also, all of these styli like around 2g. VTF. Running it at 1.5g could explain your distortion. Mine, (yellow) is set at 1.9g and it sounds good. Don't be afraid to run it at 2g+. They can take it.
I'm listening my YM-308 now. Ravel sounds great.
OOPS! I missed it! You got the JICO! Try running it at 2g or even 2.2g and check the alignment again carefully.
John
