It's a stereo recording, so in this case Channel 1=LH Channel and Channel 2=RH Channel. Basically, I'm playing a signal that "should* only be in one channel or the other, and looking at how much signal is leaking into the other channel. We want none, but as mentioned before, this isn't physically possible with the way vinyl is recorded. To get none, we'd need a theoretically perfect record and a theoretically perfect stylus. Neither of which exists.
Peak Level: Highest dB recorded for selected passage.
Peak Positive/Negative: The waveform has "positive" and "negative" peaks. These are the peak levels for each respectively. The scale peaks at 0dB and goes down from there, so the peak value will be the higher of these two (smaller negative value)
DC Offset: DC Offset would indicate a problem with the phono pre. It'd be very strange for vinyl to have DC offset. To visualize DC offset, take the sine wave and move the wave up or down so that the negative and positive parts aren't centered on zero any more. Somewhat difficult to implement in a physical groove!
RMS: "Root mean squared" dB level. Basically, take all the sample dB values, square them, sum them up, divide by the number of samples, then square that value. Think of this as the "average loudness".
RMS (A-weighted): RMS calculation with certain frequencies given more weight than others to better represent the loudness as heard by the human ear.
