MadcapLaughs
Hey just checking in here. So the pilots been running very nicely, I’ve had it hooked up for a while now with matched tube amp doctor el84s, tele 12ax7s and an RCA clear top 12au7 phase inverter tube. It’s hooked up to my Mac C29 preamp and Altec boleros 890cs.
the short of it is that this amp can sound pretty special sometimes but often I’ve noticed it’s been fairly fatiguing to listen to for extended periods. Not sure what about the amp, but the rest of my system did not have this sort of shouty aggressive tone to it when I was running my tech’s eico 22 monoblocks (6L6 tubes) for instance (all other components the same as now). I mean it can be like ice pick to the ears level harsh with guitars and rock especially, even at moderately loud volumes. I find myself just wanting to turn my system off more often than not.
Should I try different el84s or a 12au7 phase tube before deciding this isn’t the amp for me? I’ve swapped the tele 12ax7 tubes with a pair of RCAs to no avail. Any thoughts? Thanks. The amp has a recap with orange drop capacitors
