Is it built like the schematic shows? That is strange. Normally I'd expect one resistor per screen, or one that was common to both but not this. Best guess is its some sort of stability mechanism but why they put them on opposite sides per channel is beyond me. If they were doing it for some sort of balance deal it would seem it needs to be on the same leg on both channels.
The SAMS shows that the 270 ohm resistors are optional. My guess is that they are there to stop parasitic oscillations.
gadget73's post explains well the reason for the 25V bias on the filaments.
I have added a CL-80 and increased the cathode bias resistors from 120Ω to 150Ω.
I will look forward to hearing your report.... I will check back in with some pics and impressions on how the Pilot holds up against the healthy guests.
congrats on your 202t, tim. what's its serial number, and does it have an mpx installed? i put up a post in the fisher forum where i'm trying to keep the data for known owners...https://audiokarma.org/forums/index...on-thread-and-roll-call.953758/#post-14664309Quick little funner'ness. I have a buddy coming over on Friday the 3rd. We plan on doing some slippy swappy amp madness.
I have a newly acquired Fisher 202t that I cannot wait to hear. What a lucky find. I would not have even known anything about this amp if not told about them. Apparently it is a 400C pre with a tuner. Very cool and not many made. Just making sure all is up to spec before stretching its legs. Get pic up later of it it. Quit the looker.
Also, we will have a mod'd Marantz 8, and the aforementioned gear in the earlier posts with the 400CX2, SA-100/300, and, of course, the Pilot. I will be using newly found Speakerlabs K-Horn's, or "K'"?? Anyway, the Klipschorn clone. Cabs are nothing special and needs a lot of work but they sound amazing. I will also have some Cornwall's in the mix as well. This will be fun.
you might want to look at the pilot fa-690 (or 690a), iirc mine has the sum function.Hey a bit off topic, but I have a pilot SA 232 tube amp and have used several preamps with it over the past few years, but I really want to get a matching pilot preamp. However, there is a small annoyance that I can’t seem to confirm why these pilot preamps have them:
I listen to a ton of mono records and I get a lot out of using a built in mono sum function on my preamp (Mono A+B). However, most pilot tube products seem to only include mono channel A or mono channel B as two separate functions. My simple question is, if you select one of these functions, are you still getting the benefits of a traditional mono sum function when playing LPs on a stereo cartridge or is there some other archaic application for this switch selection? It’s simply a deal breaker if there isn’t any benefit during mono playback on my stereo system and no I won’t buy a mono cartridge or use a Y cable as an alternative. Thanks guys!
No MPX… sad about that… but I will get serial number this weekend.congrats on your 202t, tim. what's its serial number, and does it have an mpx installed? i put up a post in the fisher forum where i'm trying to keep the data for known owners...https://audiokarma.org/forums/index...on-thread-and-roll-call.953758/#post-14664309
i dunno. mine is packed away, and i’ve never seen an operating guide…From what I can tell there is no sum function on the 690 or 690a, only mono channel a (fm), and a separate channel b (am). Where is the typical A+B mono sum function? I dont understand why they only included two single channel options, in fact I'm not even sure what the purpose of that would be.
Separate FM and AM tuners within one unit were used for stereo broadcasts before a FM multiplex system was approved and implemented. One tuner would provide the left channel information (example channel A on FM) and the other tuner would provide the right channel (example channel B on AM). If one was not listening to a stereo FM / AM broadcast, one could use either the FM or AM tuner through both channels using the A to both channels or B to both channels mode.From what I can tell there is no sum function on the 690 or 690a, only mono channel a (fm), and a separate channel b (am). Where is the typical A+B mono sum function? I dont understand why they only included two single channel options, in fact I'm not even sure what the purpose of that would be.
