Carguy1394
Hello everyone in this forum. I will be grateful for any advice and help that someone gives me because I have not repaired any amplifier so far. This is another renovation of Pioneer A9. It differs from all the repairs described so far in that most of the transistors recommended here for substitution are no longer available. The other feature is that it is a repair of 3 A9 amplifiers with different degrees of damage. I bought one from eBay - amp number 1. It played but there were problems with its potentiom
eter
and switches and the bias was not set obviously because it was absolutely cold both at idle and when playing for a long time. I tried to adjust the bias but I must have done something wrong because the left channel exploded and a piece of 2SA1076 transistor crashed into my forehead and the 150 ohm resistance between the drivers burned with a flame in front of my eyes. The transistors on the left channel were burned out, the drivers, the double ceramic resistor, the 150 ohm resistor 05V, the A899B preamplifier on the amplifier board and the resistors. It turned out that the amplifier had been repaired many times. Just then another came out in Ebay with a defect in the left canal. I bought it right away because I thought it was easy damage or I would take parts of it - this is amplifier number 2. It turned out that it has different transistors 2SA1301 & 2SC3280 the left channel and the left channel curved over 2 watts of gain, and it was cold. I thought it was bias, but this time I put on my glasses before adjusting. I started to adjust very carefully with Fluck115 and a ceramic screwdriver. At that time, I was blown away by the heat of Pioneer A9 and the smell of aluminum. I immediately panicked and turned off the amplifier. And then I saw that the right, working channel had melted the transistors. I never imagined that bias could have such a significance for Pioneer A9. Then I bought transistors from ebay 2SA1076 and 2SC2526. I replaced the other burned parts again from ebay and proceeded again very carefully to adjust the bias This time I don't know where my mistake was, but both channels smoked from overheating. I was completely desperate that I could not repair these two amplifiers and bought a third Pioneer A9 from ebay amplifier number 3. It looks better preserved, although it has been repaired. I don't know if the power transistors are original. Here I will post photos of this investigation. I decided to check the bias just in case before there was any trouble. But this time, without turning anything, I touch the radiators at idle with my hand. Slightly warm, that's fine. I immediately measured the voltage in both ends of the resistor R1 and R2 of 150 ohms 0.5V which is on the driver boards on the right channel at one end is +0, ...and at the other is -0 ... 1volt difference In this channel is OK. But on the left it is the same at both ends +0 .... 0 volt difference Which means that no current flows through the R1 of GWX 593 to unclog the drivers. The other two amplifiers that exploded in my hands had the same problem. What can this be - bias? Drivers, pre-drivers. Anyway. I decided to throw away the other two amps and keep the last one. But then I decided to fix all three, starting with the broken ones to gain experience.
eterand switches and the bias was not set obviously because it was absolutely cold both at idle and when playing for a long time. I tried to adjust the bias but I must have done something wrong because the left channel exploded and a piece of 2SA1076 transistor crashed into my forehead and the 150 ohm resistance between the drivers burned with a flame in front of my eyes. The transistors on the left channel were burned out, the drivers, the double ceramic resistor, the 150 ohm resistor 05V, the A899B preamplifier on the amplifier board and the resistors. It turned out that the amplifier had been repaired many times. Just then another came out in Ebay with a defect in the left canal. I bought it right away because I thought it was easy damage or I would take parts of it - this is amplifier number 2. It turned out that it has different transistors 2SA1301 & 2SC3280 the left channel and the left channel curved over 2 watts of gain, and it was cold. I thought it was bias, but this time I put on my glasses before adjusting. I started to adjust very carefully with Fluck115 and a ceramic screwdriver. At that time, I was blown away by the heat of Pioneer A9 and the smell of aluminum. I immediately panicked and turned off the amplifier. And then I saw that the right, working channel had melted the transistors. I never imagined that bias could have such a significance for Pioneer A9. Then I bought transistors from ebay 2SA1076 and 2SC2526. I replaced the other burned parts again from ebay and proceeded again very carefully to adjust the bias This time I don't know where my mistake was, but both channels smoked from overheating. I was completely desperate that I could not repair these two amplifiers and bought a third Pioneer A9 from ebay amplifier number 3. It looks better preserved, although it has been repaired. I don't know if the power transistors are original. Here I will post photos of this investigation. I decided to check the bias just in case before there was any trouble. But this time, without turning anything, I touch the radiators at idle with my hand. Slightly warm, that's fine. I immediately measured the voltage in both ends of the resistor R1 and R2 of 150 ohms 0.5V which is on the driver boards on the right channel at one end is +0, ...and at the other is -0 ... 1volt difference In this channel is OK. But on the left it is the same at both ends +0 .... 0 volt difference Which means that no current flows through the R1 of GWX 593 to unclog the drivers. The other two amplifiers that exploded in my hands had the same problem. What can this be - bias? Drivers, pre-drivers. Anyway. I decided to throw away the other two amps and keep the last one. But then I decided to fix all three, starting with the broken ones to gain experience.
