Pioneer Crazy?
Markthefixer,
I think I spoke to soon. The left channel has gone out. That was the problem I was having to start with, but it started working. Now it is gone again. I don`t think I want to mess with trying to fix it. I emailed the seller and asked if I could return it. Not as described. Worth a try. It still looks good! LOL
TankDonovan
Deoxit...... It does wonders!!! (May be easier than re-packing)
Duct taped deck arrived. The seller packed it exceptionally well, almost double boxed quality packing job (for $10 sale). Prelim check showed mechanicals working great,but the vu meters were doing crazy things...
Grabbed my cleaners and went to work. Removed duct tape, cleaned off residue (yeccchhhh). Grabbed shopvac and paintbrushes, de-dusted it. Cracked lower chassis open and tilted out audio board and let the 2 long mode switches have it with deoxit and the next morning with pro-gold.
Buttoned up the lower chassis, degaussed and cleaned the tape path.
Put in a sacrificial tape.... and ... it played fine... grabbed my head alignment tape and squared it up, ran the tape through the frequency response section after I set up the fluke 8920a in relative db mode and It wasn't too shabby. Put it into record off of an fm classical station and it also wasn't too shabby.... Looks like the only fault so far that my parts queen acquisition has is a visually darker stain in the wood where the duct tape used to be. Looks like I'm going to have to break out the detail kit. :beerchug:
Markthefixer,
Sounds like you got a good deal. Why was the duck tape on it?
DeoxIT for my problem? Where would I spray it? I have two cans on order.
I have already decided I`m not going to sent it back no matter what. May have to pay to fix it but, I like it.
TankDonovan
Owner lent it to brother, brother lost 8 side screws for case and 3 top back screws also for case. (Metric but he was supposed to be in Germany) Duct tape was holding the wood cabinet to the chassis. It's still open on the bench so with a little patience, I'll shoot some pictures as best I can to show the trouble spot. Several small openings on switches that the plastic nozzle extension can access to try to get the deoxit into the contacts.
can remove bottom plate (8 screws) and then remove 4 screws holding amplifier board. Than carefully pivot it out... will have to open up a couple of cable ties to allow easier pivoting of the board (pivoting probably unintended by factory). Firmly pivot/ don't force....
Anybody else deoxiting those switches??? :saywhat:
Lets see how this works. first picture is closeup with bottom off (my bad, there are 7(seven) screws holding it on. The blue box i drew encloses the solder pads for the 2 switches... NOT some weird Integrated Circuit.
There are 4 screws on the corners holding the board. Second photo shows the board pivoted out (please excuse the thumb),
the leftmost box I drew outlines the business end of the honking big rec/plyback switching solenoid, the right boxed areas (upper and lower) are the two switches. There is nothing that goes through the square holes on the ends of the plastic sliders of the switches (for when you put it back together), the flat part of the solenoid presses on the end of the plastic PAST the holes.
The third picture is a closeup of the switches With boxes that I drew that show the holes in the metal (all five per switch, 2 small round holes, 2 ends and a double large square hole(s) in the middle) that I shot (under 1 second each) squirts of deoxit, and later pro-gold, into.
Then I mechanically actuated the switches incessantly by hand...
ct-f9191_close_bottom_mod.jpg ctf-9191_board_pivot_mod.jpg ct-f9191_switch_closeup_mod_.jpg
WARNING to those with borderline OCD... don't wear out the switches!!!!!
:naughty:
BTW: How do I get the pictures in the post, as opposed to attachments that have to be clicked on?
edit 2: Due to the great database crash, I am re-posting these pictures. They are essentially the same as the originals.
The de-oxiting of these 2 switches is CRITICAL for the good operation of the deck... even the input leads from the playback/record heads and associated signals are connected to and THROUGH this switch
attachment.php
Do you think what you show doing will help my low volume[or no volume] on left channel play back?
All other functions work just fine[time being].
I`m afraid if I get it apart that I might not be able to put it back together.
TankDonovan
Just for grins I would clean the head(s) first, it's quick and easy.(q tips and alcohol) All the audio runs through that switch. As long as no wires break, and they all go back where they came from, without being pinched by mounts or solenoids, nothing bad should happen. But I cannot speak to unspoken assumptions..(i/e ground rules). Lost screws, forcing things, finger tight versus torqued correctly versus gorilla tight etc...
I felt a little anxiety the first time I did that 9191 pivoting manuever, so I went slowly investigating every increment of movement and resistance, always keeping the graceful exit option viable. Nothing is going to jump out, fly off or etc and the solenoid actuation of the switches not a thousandths of an inch critical adjustment, the board screw holes realigned everything nicely, just watch the few wires going near the solenoid "finger" and the pc board mounts. These decks were built like tanks....
Good lighting and a flashlight helps, as well as a clean area to work in. :thmbsp:
But I have been taking things apart since I was knee high to a grasshopper, and putting them back together correctly without "extra" parts shortly after that. :nutz:
He has 2 for sale, but I can't afford postage, I would have chased them if I could have picked them up. but they're halfway between the quad cities and peoria, and the gas costs would have rivalled the postage. SSSooobbb I can't save them all..... :naughty:
Hey tank... how's yours doing???
Yea, shipping cost keeps me from bidding on alot things. It seems that if I`m interested, it`s in Calif.
My deck still has the "plays right sometimes and sometimes not". Left channel still comes and goes[goes mostly]. Really, have not had time to check it out real good.
TankDonovan
Markthefixer,
I finally got time to work on the deck. Your advice was right on. I did just like you said and my deck works perfectly[both channels]. Now all I need is a real small rubber band for the tape counter. Thanks, for your help.
Reading your posts here made me jump into the CT-F9191 game...I posted pictures in the pioneer forum yesterday...a good number of views but nobody seems to have much commentary there (or any at all for that matter)
Got a great deal on an all original working deck that looks good, too!
It has a bit of static in the line switch and the fastwind works pretty well but seems to slow down when more tape is on the left hand spool. Any ideas here? Seems more like a tired motor than this issue with the clutch mechanism you speak of...but I could be wrong.
This post has inspired me to crack open the bottom of my unit once I get a new can of spray...think it will help with any of the background white noise?
...Also...my +5dB peak light for recording seems to hit when the needles are in the -3dB range...do these VU meters just not react to quick peaks very well or do you think they they are they in need of adjustment?
Typically, decks of this vintage, in raw/unrestored state, could benefit from a good REC/PLAY/DOLBY calibration. That being said, the peak indicator responds to rapid peaks, while the meters are designed to indicate slower average readings. This help you to properly set recording levels, and is quite normal, and in your case, sound about right.
Enjoy,
Rich P
Does anybody know the belt diameters? Also, where is the third belt? I can only find the capstan and the counter belt in the service manual.
Thanks markthefixer and audio karma search function! I now have my trusty old deck off the basement shelf and on my rack where it belongs. Pictures were very helpful.
Spoke too soon. The hum is back in the right channel, but now at least the music plays where prior to disassembly there was no playback heard, just hum.
