Tengo el mismo problema, en breve procedo a desmontar y limpiar los interruptores con lubrilimp
Lets see how this works. first picture is closeup with bottom off (my bad, there are 7(seven) screws holding it on. The blue box i drew encloses the solder pads for the 2 switches... NOT some weird Integrated Circuit.
There are 4 screws on the corners holding the board. Second photo shows the board pivoted out (please excuse the thumb),
the leftmost box I drew outlines the business end of the honking big rec/plyback switching solenoid, the right boxed areas (upper and lower) are the two switches. There is nothing that goes through the square holes on the ends of the plastic sliders of the switches (for when you put it back together), the flat part of the solenoid presses on the end of the plastic PAST the holes.
The third picture is a closeup of the switches With boxes that I drew that show the holes in the metal (all five per switch, 2 small round holes, 2 ends and a double large square hole(s) in the middle) that I shot (under 1 second each) squirts of deoxit, and later pro-gold, into.
Then I mechanically actuated the switches incessantly by hand...
View attachment 11200 View attachment 11201 View attachment 11202
WARNING to those with borderline OCD... don't wear out the switches!!!!!
BTW: How do I get the pictures in the post, as opposed to attachments that have to be clicked on?
edit 2: Due to the great database crash, I am re-posting these pictures. They are essentially the same as the originals.
The de-oxiting of these 2 switches is CRITICAL for the good operation of the deck... even the input leads from the playback/record heads and associated signals are connected to and THROUGH this switch
