Good morning all,
I've had a Pioneer PL-A45D for a while now and it's in *mostly* good shape. Could use some lubing up and all, but the auto return works and the sound is good. Nice!
Problem is, it suffers from that intermittent buzzing issue that many of these units exhibit. This has been documented in other forum posts, and rarely occurs during actual music playback. It's quite jarring and I'd like to fix it. I forgot just how I came to this conclusion, but I recall narrowing the source down to a microswitch (or stacked pair of microswitches); these are shown as part #22 on page 11 of the manual. Part #KSF-009-0.
A few years ago I was able to find an exact replacement for this part, although it seems it's no longer sold and the only replacements are donor parts on Ebay. Does anyone have a source for these they could share?
A little more background: I have had this turntable for several years and it's always been kind of a black sheep/problem child. I've held on to it because I really like the aesthetics of it and I'm also hopeful that I can improve its function little by little until it's basically good-as-new. If anyone knows anything about these decks and the problem I've described, please do share. I believe the microswitches I mentioned control the auto-return mechanism, timing, etc. so I'm not sure how they could possibly interfere with the audio, but I've ruled out the signal shorting switch and other than that there isn't much to investigate.
Cheers
Cheers
