Hi,
I have two Pioneer PL-L1000A turntables (had them since new). They have been in storage for quite some time but now that I have some extra spare time, I have taken them out of storage for some much needed work.
To the point. Some years ago we moved house and it appears that one of the boxes that was to go with us, did not.
It included (amongst other important and probably irreplaceable HiFi stuff) all the extra counterweights for the Pioneers and other things such as the cartridge alignment guide and packing materials. Sadly the original packing boxes of these TTs and my Beogram 4002 did not survive - a very sad tale.
I am hoping that someone can help me out with some information on the counterweights and the guide so I can replicate them. Specifically, I need the dimensions and weight of the large counterweight and the threaded sub-weight, preferably in metric
but imperial or USCU would be fine.
Similarly, the dimensions of the alignment gauge (Pioneer call it an overhand gauge - well I suppose, strictly speaking, it is) would be gratefully accepted. The most important measurements with the guide is the distance between the alignment line and the inside of the vertical piece. Also, the distance between the bottom of the notch for the head-shell connector and the top of the horizontal piece.
Photographs with the items next to rulers would also be gratefully accepted. Placing the rulers as close as possible to the items would help to reduce errors due to parallax and perspective.
The two tonearm arm packing piece are also missing, the one that sits down on the rails and the one that clips over the top of arm as well as the three machine screws that hold down the suspension during travel and the 4 screws that hold down the tonearm during transport. I could work out the machine screws but it would be so much easier to get the information from someone who has them at hand - I can be a lazy ... .
All of these components are likely metric.
I do not know whether these parts are the same as was used in the Pl-L1000 or the Phase Linear 8000, I do know that the Pl-L1000's owners manual does not show the sub weight.
All the fluid leaked out of the level gauges badly damaging some paperwork. In a moment of disgust I threw them out <sigh>, does anyone have photos? <he asks sheepishly>
I have a number of other issues such as the rubber spring boots, corrosion of the plastic control button facings, and a fault in one TT's tonearm drive - all probably best addressed in future posts.
Thanks for any help,
Regards,
Bob
BTW
Sorry about the thread title, I can't seem to edit it
BTW
I have already posted a similar message in vinylengine forum, but so far, no luck
Regards,
Bob
BTW
BTW
