Blackbear
Greetings! After a few weeks of the PL-6A running fine, the startup speed has become sluggish. Before I replaced the Cap gadget73 suggested and it seemed to correct the problem. Now upon startup, I'm back to sluggish, inconsistent speed. 4 min running and it's pretty much back to steady. Is there a chance the cap needs to be larger? If I can try that, could someone suggest one to try? I'm still learning about values and meaning. Would a larger cap help with the speed issues? Member Metalonz says his PL-6A is up to speed within 1/2 turn, so I know it's possible. If there is a motor problem to consider, would the motor get to a good and steady speed at all? I think this little table has been abused so perhaps the motor was run without proper lubrication. I've never pulled and opened a motor.. maybe this is the time to learn. Thoughts? Should I try a larger Cap? Thanks for your time and consderations~
