Good afternoon, hope everyone is being careful, taking necessary precautions and is doing well! Like many of you, I have some extra time to catch up on my stereo projects (so far the wife has been quite patient)! I am in the process of restoring my SA-7500 integrated amp. I have replaced the capacitors and bad transistors on the Control Amp AWG-033 as well as the Equalizer Amp AWF-018A (manual states AWF-015B, board is marked AWF-018A). I was admiring my work and loving the sound (and not being too careful) when the Control Amp board got too close to the 10,000uf capacitor mounting bracket. Sparks flew, sound cut out and the protection relay kicked in. I think pin #7 was the offender.
I have checked the output transistors, they are all fine, I have checked the driver transistors (pulled W7 the D357 and it tests fine). I measured the other D357 as well as B527 and get voltage on them all. Some voltages are spot on, others vary. Here is what I am getting:
AWH-040 Power Amp
Pin 33 40.4V should be 38V
Pin 28 -40.3V should be -38V
Pin 22 40.3V should be 38V
Pin 9 5.38V should be -40.5V
Pin 6 36.5V should be 37V
Pin 10 0.74V should be -15V
Q7 base 6.99V should be 1.2V
Q3 base 4.6V should be -1.2V
Q10 base 4.7 V
Q8 base 6.9V
I will measure voltages on Control Amp, EQ Amp and Power Supply when my wife allows!
I have not looked at the relay as of yet. Any early indicators or suggestions?
I thank you all in advance!
AWH-040 Power Amp
Q10 base 4.7 V
Q8 base 6.9V
