don't read too much into it, first the readings have to be absolutely repeatable. including the rails.
happenstance.
happenstance.
C15 being changed to an ecq is very good thing.
protect could be several things, up to C9,C10 Q1, Q2 over current sense
BUT FIRST
does it do it when the amp is both quiet AND carrying music?
does cutting out the tone controls make any difference?
measure the DC voltage at the speaker terminals while turning up the volume knob to -37db with no audio. on this amp there is no dc offset adjust...
see if the dc voltage changes with tone control in and out, as well as various volume control settings.
we are looking for DC going into the power amp AND the input caps (c1q,C15L / R ??) leaking and letting it in.
if it does it on music only
then q1,q2,c9,c10 bear replacement. this is more likely.
does it on music
q1,q2,c9,c10 need replacement.
q1,q2 512-KSC2383OTA ecb left to right, leads pointing down, flat facing you. old 2sc869 = BCE, WARNING IT IS OPPOSITE!!!!
c9, c10 667-ECQ-V1224JM
does it on music
troubleshooting
open up D21 (lift a leg) and see if it still goes into protection (defeats over current protect)
did that stop it? (leave d21 open )
open up D22 and D23 together and see if it still goes into protection (defeats DC voltage protect)
it should still delay several seconds upon power up.
we gotta see if the protect circuit is JUSTIFIED in tripping the relay...
does recap mean c11 and c12 (330uf 6v) were replaced? Q3 and Q4 (2sc945) can be replaced with another 945 set OR a pair of ksc1845's...
troubleshooting
