Hi guys,
I have had a beautiful Pioneer SA-9500II in my possession for a couple of weeks now. The amplifier was cosmetically in perfect condition although I could tell that it had been forgotten in a warehouse for many years. So I have cleaned it inside and out and adjusted the bias current. I tested it with the oscilloscope, to later connect it safely to my speakers. It sounds pretty good, although I can tell it needs some restoration, which will be done in the next few weeks.
A few days ago I wanted to move it a little and I felt a tingling sensation when I touched the lid. I immediately unplugged it and searched AudioKarma to see if anyone else has had this problem. I found this thread where a member suggested trying plugging the amp in one direction and then the other. This has helped, the plug is not original. Someone has cut the end off and replaced the plug, without changing the power cord (see picture). The original power cord only has two prongs, so looking at the schematic, when plugged in one position the hot wire goes to “ground/chassis” and that is where I feel the tingling. If I reverse the plug, the neutral goes to amp ground and the hot wire to the power switch.
So my questions are:
Is this “normal” or safe? What should I do?
Thanks guys, any suggestions will be appreciated.
Have a nice day
Have a nice day
