Craig Skeet
Member
Hi,
This is my first post on AK.
I just bought a Pioneer SA-9800 that was supposed to be fully working. I've been looking for one for a while and thought I had a good one ready to fully restore by re-capping and replacing some of the known bad transistors.
On inspection it had a very odd modification which resulted in the sound being attenuated to approx 25% of what you would expect from a 100W amp and loss of the loudness function.
The PCB from the volume pot was removed, this board was bridged with resistors and the volume pot was connected between the output on pre amp board and the main amp board inputs.
The normal wire connections to the preamp out and main amp in RCA connectors were removed.
Very strange.
With this modification although the volume was very much attenuated, there was only a quiet, acceptable hum, but no loudness function (not connected).
I managed to speak to the tech who did this (contact details were on a supplied receipt)
He told me that this modification was done to attenuate the hum, against his better judgement as the previous owner just wanted the hum gone and didn't need the amp to be very loud.
I reverted everything back to how it should be, reconnecting the volume pot PCB, re-connecting the pre-amp out socket to the preamp output on the filter board and re-connecting the main amp input sockets to the main amp boards .
The hum /buzz is quite bad.
From the speaker outputs (links in place) measured with a scope, it's 32mV pk to pk at 100Hz. Both channels.
Interestingly there is a 250 mV DC offset. (not present with the strange modification)
From the preamp output there is a 5mV pk to Pk (1mV RMS) 100z signal with no offset.
The hum is the same when I connect a source to the main amp in connectors at the rear of the amp.
The power supply board has been very recently re capped I am informed and this is obvious looking at the board.
I've checked for poor grounds, loose leads, obviously bad components, and broken bridged PCB tracks, etc.
The main filter caps appear to be in fairly good health with satisfactory capacitance and low ESR.
I have not checked if the hum is present/ same when connecting pre-amp out to another amps main in yet, but will try this when I dig out a suitable amp.
I'm really stumped.
This amp really should be restored to its original glory.
Are there any Pioneer experts out there who may have come across this problem
Any help would be really appreciated.
Very strange.
I'm really stumped.
