randallflag
Vae Victis
The Bourns pot replacement info is in another thread. The link is here
http://www.audiokarma.org/forums/showthread.php?t=409557
Sorry, we were posting at the same time.
larryderouin said:No attitude. I don't know your level of expertise is all, so I tend to the novice side to be safe. Sorry if I offended.
The way you wrote the DC Balance sentence, it reads that between pin 26 and ground it should be 60mv. Which is not what the manual says. It says 0 with a variance of plus or minus 60mv. That gives you a spread of 120mv and the one side is just over 10% out of spec. Doesn't matter whether it's minus or positive voltage. But the closer to zero you get on the DC Balance the better. Like I said previously and Solutionroom backed up, the pots are very twitchy. So you'll get large swings with just touching them.
larryderouin said:ADD ON: Lee, I went back and read that sentence for the 11th time. 50 VOLTS????? No wonder you got hot under the collar. I do Apologize. I don't know how I missed the lack of "milli". I'm sorry, man. You definately got something wrong. I'd start by pulling the outputs on that side, and testing them. A power up might be something to look at while that side's outputs are out if it's safe to do so on this amp. Some are, some aren't. If not you're limited to testing the outputs by DMM.
With it being Minus(-)50V check Q8-Q10(Outputs) & Q36(driver) and the .47R emitter resistor(R-82) on the negative rail.
Larry
These are from solutionroom's 9800 thread.
http://www.audiokarma.org/forums/showthread.php?t=409557&page=2
Only thing you did not do was to measure the voltage on the two wires you removed from the bases of the transistors (after all, that kinda completes the t-shooting circle, does it not?).
The 2SA979 and 2SC2291 are tough to find. Littlediode carry them, but you'll pay a premium. The rest of your choices look OK, except the drivers, which are hella slow. I prefer the Toshiba 2SA1837 and 2SC4793 in this case (Digikey).
I'll look at the diodes and post back, but except for the zener and the bias diodes (D9,10), looks like most are vanilla 1N4148 signal types.
I'd say it's just about a certainty.Yeah, I could have done that. That would have shown whether one of the outputs was being turned on by something further upstream, yes?
Yes.The drivers are the 2SC1913 and the 2SA913 correct?
It appears that there is a transistor that is shorted, and that has the output stuck at the + rail. You'll likely confirm this by checking the voltage on the removed wires.Just wanted to make sure we're talking about the same thing. I figured I'd try replacing all the transistors except the 2SA979 and 2SC2291, do you think that is wise? If they are bad, perhaps they might take out the new stuff further downstream.
You will notice that I've upgraded some of the resistors. Places where there were 1/4w resistors up on stand-offs, I replaced these with 2w ones.
I just said it looks pretty....
