I kind of figured that since they can only attach to the heat sink one way. Good to know but still puts me in a bad place. I might just buy a new used Power Supply Board from Ebay.Those TO-220 package transistors are the same Pinout. They will install the same as the original.
The collector on the TO-220’s is the middle leg and the flange that the mounting screw hole is. This is important to know.
You are on the right track. This hobby has many knowledge paths and each needs to be explored. It’s not a waste to learn and apply your new found skills.
That's not a guarantee.I kind of figured that since they can only attach to the heat sink one way. Good to know but still puts me in a bad place. I might just buy a new used Power Supply Board from Ebay.
Yep, those are 100% the exact same parts that I ordered and installed all correctly except for the one KSC2383YTA that I put in backwards them flipped around.That's not a guarantee.
Loosen up harnesses to gain what you need for access.
I bet he board has been through a war.
Still. Try to salvage it.
Power Supply Board (AWR-094)
Old list may need equivalents.
AWR-094: C1: 100uF 63v CEA: 647-UPW2A101MHD 100uF 100v
AWR-094: C2: 100uF 63v CEA: 647-UPW2A101MHD 100uF 100v
AWR-094: C5: 220uF 35v CEA: 647-UPW1H221MPD 220uF 50v
AWR-094: C6: 470uF 50v CEA: 647-UPW1J681MHD3 680uF 63v
AWR-094: C7: 470uF 50v CEA: 647-UPW1J681MHD3 680uF 63v
AWR-094: C10: 100uF 50v CEA: 647-UPW2A101MHD 100uF 100v
AWR-094: C11: 220uF 25v CEA: 647-UPW1H221MPD 220uF 50v
AWR-094: C12: 330uF 25v CEA: 647-UPW1V331MPD 330uF 35v
Q1: 2SD313: 863-MJE15032G
Q2: 2SB507: 863-MJE15033G
Q3: 2SC869: 512-KSC2383YTA
Q4: 2SA628: 512-KSA1013YBU
Q5: 2SC945: 512-KSC2383YTA
Q6: 2SA628: 512-KSA1013YBU
Q7: 2SD313: 863-MJE15032G
Which location was that part put in backwards? It might have contributed to other parts going bad.Yep, those are 100% the exact same parts that I ordered and installed all correctly except for the one KSC2383YTA that I put in backwards them flipped around.
It was installed in the only place it was supposed to be in. Maybe Q3 but I don't know how to read a schematic. If you look at this photo it is the transistor with the white paint on top of it. I believe it blew the Zenor Diode as discussed earlier and I installed a new diode and started getting voltage readings on pins 1 thru 5 but not the correct voltages. Someone stated that I may of used the wrong voltage Zenor Diode but there are absolutely no numbers on it so I don't know how to tell other than they are totally identical.Which location was that part put in backwards? It might have contributed to other parts going bad.
nashou
The resistors on the blue box do not pass visual inspection (R5-R6), if they are open you will see full positive rail voltage on pins 1~5. I strongly suggest to be tested with DMM and post the values. IF the OP do not know how, just ask.
If you guys need me to identify the Emitter, collector/ base on the board just ask.
Source:
Page 33 service manual and post #7
HIPOCRATES
The usually go open... and measure on legs with the Ω setting1 - 2.78
2 - 7.98
3 - 2.65
This should be the values.
Only those resistors, they are critical. IF D1(24V Zener) and all the transistors are correctly installed. That board should work.Is there anything else you would recommend I replace?
Emitter-Collector-Base2SC945 Transistor
Here is the data sheetCan someone give me the 100% correct PINOUT of the 2SC945 Transistor. These are old and no longer produced and I have researched on line and found confliction data because AI is stupid.
Thank You
Well, I had to flip 2 more around for the second time on the Mixing Amp Board. Yes I know, that's not its actual name but I've had one hell of a day.Emitter-Collector-Base
