rowingcoach
I have installed the resistors you recommended. the 1k 1 watt ones.
First, before power is turned on, we set the positions of the VR pots on each board.
HOw is this accomplished now that they are installed UHG. :sigh:
and have been turned every which way from how they arrived from Mouser? I am trying to spin the 2k ohm one and it seems to spin forever in every direction no matter how long I sit there turning it. Is there supposed to be a hard stop? I know it is a 20 turn or so, but both pots behave the same.
Both VRs are the ones I ordered from the parts list.
This minimum setting , results about 0.4 to 0.6 volts positive (to chassis ground) on pin 10
and -0.4 to -0.6 volts negative (to chassis ground) on pin 13 IF THINGS ARE BEHAVING THEMSELVES.
These voltages will eventually go to the output transistors and tell the output transistors what to do.
IF things are not behaving themselves, the voltages can be far far from the 0.6 volts or so. like 2 volts or 30 volts... (the 10 ohm resistors will pop)
This is as far as I got. ON the board on the right side I get low numbers between -.7 and .7.
On the board on the left I get WILD numbers that vary up and down between - and + number as high as 15 and low as -4.
I tried this a bunch of times to be sure my connections between the added resistors and the boards were good.
What does this mean?
So the process is to chassis ground the black dmm lead, turn on the power and read the voltages found on pins 10, 13 and the resistor's common pin 19 with the red dmm lead.
IF any voltage is GREATER than one volt either positive or negative, shut it down
This is where I stopped today. Left board varies greatly and neither pot seems to change the readings. RIght board seems like it is behaving.
ADDITIONAL NOTES:
Right board is a replacement from Zebulon. it is a A revision board with the extra Capasitor
LEft board is the original board and is a D revision.
Board boards have the same transistors and caps, plus A has the extra Cap.
The BIG .5 ohm resistors are all testing in spec.
NO other resistors or diodes have been touched.
