lopezluna
YesYou are welcome!
Did the Surge killer relay pull in? Did the Protection relay pull in? May both be a bit slow on DBT.
See if the DC offset is adjustable. It should adjust even without the output transistors connected.
Then, make sure the bias pots are set to minimum (0Ω), connect the output transistors and power up on the DBT.
Recheck and set dc offset.
Then, still on the DBT, see if the bias adjustment for one channel causes the bias to increase close to its spec. It may not go that high while on the DBT. You are just checking circuit function adjustability here. You may see the DBT bulb brighten as the bias adjustment test is made, that is normal. Turn it back to minimum.
Then do the same an the other channel.
Both should be at minimum before you go to full mains. If you leave them where they set up on the DBT they WILL be too high on full mains.
Then go to full mains. Both relays should pull in quicker. Recheck power supply voltages, including C1, C2. Recheck/adjust dc offset. Then set the bias properly for each channel. Monitor bias for a few minutes to verify it is stable.
If it is happy with those settings try some music at a low level. Use sacrificial speakers just in case. If it continues to be happy play it at a higher level and let it warm up. After the heatsink has warmed up a bit stop the music input and recheck the bias and offset. Both will vary some as it warms up.
I did hear the relay click after a few seconds of powering it up. Remember the last power up was no longer on DBT. I will now go and connect to DBT and do as you said. I will give you a update shortlyYou are welcome!
