the pre-amp works like a charm by itself, only acts up when the jumpers are in and only on the left channel. i have it's jumpers out and am using the pre-amp section of it with my yamaha power amp and it rocks. i can't wait to get it to where i don't have to worry about it tearing up at any time. is there any way you could post a bom re-build list of AWH-048, mark? i think i'd be better off to replace every transistor on AWM-091 instead of just 3.
are there any way to drill a real small hole in the volume pot to get deoxit in better instead of taking it off the board?
it is already listed in several places, I will look for them before monday daylight, and check for obsoleted or oos parts. If you find them first and post a copy here, I will get to it a bit quicker... KingBubba's thread??
Clean the bare wire jumpers and the RCA sockets on the back panel, because that sounds suspiciously like a bad connection - problems should be tripping the protection, and problems IN the amp circuitry will continue even if the jumpers are pulled.
did you clean the amplifier card pin connectors?
what happens when you run a signal IN to the amplifier inputs from ANOTHER signal source (with a volume control
)you can also take a pair of cables and run the left pre-out into the right amp in and the right pre-out into the left amp in and see if the symptoms change places. As well as running the left pre-out into the left amp in and the right pre-out into the right amp in to see if the bare jumpers are doing something unexpected and unusual to you..
I had some terrible commotion once with a receiver as I moved it around on the bench, some grounded metal was hitting the bare surface of those metal jumper loops. - ouch - my ears -
