Brivan
Well-Known Member
Hello, everyone
I've been trying to diagnose a low-level audio hum in a Pioneer SX-1280 but, so far, have come up with nothing. I've read other threads in the Pioneer forum that have dealt with the same hum issue, but my situation appears to be a bit different from the others.
The receiver appears to be all original, with no apparent mods to wiring or components. I've checked voltage readings from the power supply and protection boards and all are normal. I've replaced all electrolytic capacitors on the power supply board as a preemptive strike, but the hum noise remains.
I get the humming regardless of what's done with any of the controls on the front (except for the speaker switches, of course). The hum quiets down considerably with the preamp out / main amp in jumpers removed, but it's still present and somewhat more pronounced in the left channel. The hum is in the speaker outputs as well as the headphone jack output. O-scope audio screenshots taken were connected to the headphone jack.
If anyone has any insight as to what I should look for next, it would be appreciated. Are the 4mV ripple voltages coming from both the +32v and -32v power supplies normal, or should they be flatter? The waveforms seen are pretty much a constant 120Hz - due to the irregularity of the waveforms, my scope got a little confused on some of them, but the sec/div adjustment knob was left the same for all readings. I'm assuming this is going to be a grounding issue, but I haven't seen any obvious grounds disconnected.
Below are screenshots from my scope.
+32v from power supply board:
-32v from power supply board:
+13v from power supply board:
Audio output with jumpers installed:
Audio output with jumpers removed:
Thanks!
Thanks!
