Hooray!
Its a tentative fix. Just go through all the voltage regulators pre and post voltages and make sure everything looks ok.
Maybe on thing to think of as to why this one is different is maybe the primary voltage selector (if it has one) and perhaps the tungsten panel lamps? These do draw quite a bit of power when compared to idle power consumption so if these were off/out/dead/converted to LEDs on other ones, that might point to a discrepancy.
My DBT is made up of three bulb holders - one permanently wired and two switchable. That way, I can mix and match wattages and also check how an amp behalves with a little bit less or more "leash". If I'd had you're problem, I would have switched an extra bulb into circuit briefly to see if that stopped it.
In the end there's been a lot of changes. Might be worth cataloguing/listing them and having a little look. I would suggest i probably isn't C1 - C4. I often find them at around 8nF and I do change them anyway. It could've been a bad diode...?
