Hello Ak'er,
I have a SX-1980 monster in for a re-build, it was working for a while when I received it. The owner wants it re-capped, new or re-built PS etc. The PS had repairs done to it already, what else the +80V reg blew, but the owner was wanting a new PS pcb installed because we can see the old one has been hacked at. I am still waiting to get the new PS, months have passed, I want to get this moving and done, so I will go ahead and design the pcb.
This is a low volume item, so not much return on investment for time and resources, none the less I continue on this quest in interest of science. Wife thinks I am nuts as I should be working on the garage electrical, insulation, walls, but I will use the its cold story and run with that
I can call it my new job for now.
While I was adjusting the wonky tuner and testing out the unit, I heard a loud POP, the PS blew, the top of Q209 blew its lid, the -ve 80 smoked, with it sitting on its side, the bottom plate off.
So now I have a dead SX-1980 PS. The original PS is a bit of a PITA to service since you have to remove the transformer secondary wires to get access to the back side. I can see the remnants of the last job
I'll take a pic.
We had been discussing this in another thread, so I suggested I'd take a stab at a new PS design, thus this thread to discuss the design and review what I have come up with.
We all know that this original PS design has issues, based on failures and user reports, heat is #1, no ventilation and under sized HS's. jfet constant current sources (CCS) fail regularly, so I have decided to use much larger heatsinks, EW's CCS ckt, the Pioneer mod to double up the zeners, terminal blocks for easy install, service, etc. The pcb will be spec'd to use 2 oz copper and be double sided and lots of copper to strengthen it up. I want to keep it as low cost as possible.
I am not convinced that one has to remote mount the hot regs, if the PS heatsinks are sufficient in size, so I will go that route. It is a fair amount of work to remote the regs, drill, tapping of the PA HS's, wire harnesses etc hopefully can be avoided with this new design. If someone wants to remote mount the regs then they can always do so, but my first attempt is to use much larger HS to start with.
The plan for me is to do the re-design, build, test, then if all goes well, I can offer the pcb's blank or stuffed/tested as required.
I have the first pass at the schematic done (see attached) and am presently in layout to do component placement etc. I still have to remove the old PS and measure the pcb size, mounting holes, determine the max comp heights etc. Pls let me know if you see anything wrong with the schematic. I will also include the preliminary BOM, so you know about the component choices I have made.
One issue that I have a concern, is continuing to use the PA3004 speaker protection device. Can we rely on getting them? There is the option of re-designing the protection ckt, but that is another task. For now I'll use the PA3004 as is.
At one time I did a PS re-design in ltspice simulation, making it a dual tracking +/- regulator with current limiting, but for this rev, I think I will keep it as close to original as possible except for the newer CCS, much larger HS's, terminal blocks etc..
All input is welcome.
Time for me to march on ...
Cheers
Rick
Cheers
Rick
Tech stuff rules, tho I don't understand it.
