discrete transistors . b1+ is derived from a single diode and a couple of transistors etc for regulation . there are many things that might be shorted . i would start at supply looking for shorted caps etc . i might disconnect the wire going to amp board first . then see if current draw drops .Can't remember off the top of my head but does the 424 use an amplifier block or discreet transistors?
But yeah, something is drawing too much current. In my experience it is usually a rectifier bridge, filter capacitor, or output transistor or amplifier block. The power transformer is only suspect upon the previous mentioned things being good. Power transformer failure is rare so that is why I suspect it (if at all) last.
check the rectifier diodesI have a similar issue. Board is the AWR-059
I recapped my power supply and when I went to check the voltages I accidentally shorted pin 4 and 5 I believe.
After replacing the fuses no voltage was right, I got 3v at the speaker terminals, so I pulled the board, tested every part, no issues, put it back together and connected only the transformer side.
everything was good.
18V AC on pin 7 + 8
27V AC on pin 9
14V AC on pin 10
DC SIDE
14,4 V on pin 2
25,5 V on pin 3
-25,5v (service manual shows 24)on pin 4
+25,5v on pin 5
but base collector and emitter voltages check out as well.
when I went on to connect the wires of the filter caps to pin 4 and 5 both 3.15A fuses blew again. main filter caps are replaced and test OK.
what did I mess up shorting pin 4 and 5 in the first place?
I removed and checked every component on the power supply board. I get all the proper DC voltages on the board but blow fuses when I connect the filter caps or the AF board.check the rectifier diodes
output transistors?outputs shorted then
yesoutput transistors?
q21 and q23 are shorted between E and C. thanks
