gleegum
I has this SX-450 that works fine except that the right channel in phono mode has low volume.
I've tried a different turntable and swapping cables but the problem persist.
I did a repair on this unit some months ago, it was blowing fuses, two output transistors were shorted.
Also fixed the power switch, it had the typical flickering lights issue.
I never tested the phono input until now, So I just discovered this issue.
All other modes AUX/FM/AM works fine except for the phono input.
Left channel works fine.
Any guidance what to check?
Thanks!
Thanks!
