My SX-50 has suddenly started acting really weird. This afternoon, I turned on the stereo, and the relay took around 10 seconds to click on. About 5 seconds longer than usual. I hit the speaker A switch, and was greeted with loud, scary pops through my speakers as the relay started clicking off and on at random. I shut off the stereo and disconnected everything.
I thought that the bias may be at issue here, so I turned the bias pots to 0, sprayed them with some CRC contact cleaner, and readjusted them back to 5mV. That still didn't fix the issue.
I then checked the DC offset of both channels at the speaker terminals. The right channel sat at 25mV, while the left channel was rapidly fluctuating from the negatives all the way up to 60mV. Seems highly unusual.
Now, here's what I discovered. When the stereo is powered on, it just sits idle with a buzzing sound only on the right channel, indicated by the on-screen output level meters. However, when I turn the sub-sonic filter switch, the relay will click off and not turn back on until I restart the stereo with the sub-sonic switch off. I'm thinking that my problem lies in the tone section of the board. Any ideas?
EDIT: The relay NOW refuses to turn back on until the sub-sonic switch is depressed. There's a 3 second delay until the relay turns back on after I release the sub-sonic switch. It's not only the sub-sonic switch, either. The relay will also click off when I turn on the simulated stereo switch, and click back on after releasing the switch. Where do I start from here?
