Well, I finally received and replaced the main caps and put the bypass cap across the terminals of the power cap and wow! Even better then before, and I thought that was good! I have had it playing for a while to break in the new caps and it keeps getting better and better.
Thank you, thank you, Mark for all you have done, you ARE the man.![]()
Once the amp and your ears have settled in together, try putting similar caps across the two big output capacitors, and see how that does... Sometimes it's good, sometimes it isn't...
