mattsd
Hi everyone!
I've been lurking around for a while and decided to join. I've had a very frustrating SX-525 that has been stumping me for awhile. I got it with both channels blown and through this thread: http://www.audiokarma.org/forums/showthread.php?t=269939 helped me with replacing the main amp board and power supply board transistors. I've replaced both of the 2sa489's and 2sc789's. I also replaced the 3 of the
2sc1318's. Every other transistor tested fine. I also recapped the power supply board and replaced the 2sd313. All the voltages test out fine on the power board.
I hooked the 525 up to a dim bulb tester and when turned on it goes bright as the caps charge and then dims, then starts to go bright again, and the output transistors heat up. I hooked a DMM to the speaker outputs and measured 11v dc before I switched it off so the transistors didn't heat up too much. I'm not sure what I should look for next, a bad cap? I've checked all the solder joints and proper transistor placement.
Any ideas? Markthefixer, do you have any ideas?
Matt
Matt
