Hi, greetings from a beginner in the Hi-Fi world. I’m not unfamiliar with electronics repair and working with a soldering iron, but I’m still an amateur and mostly involved with retro computers. I recently bought a Pioneer SX-535 that wasn’t producing sound from the right channel. I opened it up and after a visual inspection, I found a cracked transistor (Q10 on the AWH-035) and a burnt resistor (R-28).
I ordered replacement transistors for the entire AWH-035 from AliExpress and replaced all of them on the channel with the cracked transistor, as well as Q1 and Q3 on the other side. I also replaced Q11, Q12, Q13, and Q14, so on both channels.
Before installing the components, I checked them with an LCR-T4 component tester to make sure of the polarity so I could place them correctly on the board. However, Q13 and Q14 (KSB596YTU) turned out to be reprinted fakes — they weren’t PNP transistors but NPN ones. I hadn’t paid attention to that, even though I had the component tester, I only checked the polarity.
After the first power-up, fuses F7 and F8 blew. Later, I ordered and installed new Q13 and Q14 — this time I checked them, and they really are KSB596YTU PNP transistors — but F7 and F8 blew again. I’m posting here the voltages I measured on the AWR-067 pins.
Any help is welcome…
